Activity Forums Apple Final Cut Pro Legacy Final Cut Pro Sequence to Avid Digibeta
  • Final Cut Pro Sequence to Avid Digibeta
    Posted by Mark David spencer on January 18, 2008 at 12:09 am
    Hi Guys, I am curious if anyone knows what the best method of getting my 4 channel audio FCP6 project onto a digibeta tape from a deck that’s hooked up to an AVID.
    I have a dream…that all media production is 5% technical/95% creativity and not the other way around.
    Matthew Nelson replied 18 years, 8 months ago 3 Members · 2 Replies
  • Michael Gissing
    January 18, 2008 at 12:55 am
    Is the FCP project just audio? Do you have a card like AJA or Decklink in the FCP machine?
    If is just audio then export the audio tracks to the AVID & restripe.
    If not and you have a card, then hook up the digi beta to FCP & edit to tape. So many options – so little information
  • Matthew Nelson
    January 18, 2008 at 12:59 am
    Here are the options I can think of.
    1. Export a self contained QT then export your audio channels as WAVs or AIFF which ever the AVid reads best. Import these files into AVID then lay back to the Digibeta.
    2. Use Automatic Duck to translate your FCP project into an AVID project.
    3. Get a capture card for your FCP system and go to the Digibeta directly.
