Activity Forums Apple Motion Final Cut Pro Send to Motion causes interlace problems?
  • Final Cut Pro Send to Motion causes interlace problems?
    Posted by Deborah White on March 7, 2010 at 7:48 pm
    I wanted to use the image stabiliser in Motion. In my FCP timeline I sent the clip to Motion but in Motion the clip has interlace issues that where not apparent in FCP. What is causing this and any thoughts on how to solve it?
    Is Motion using a different codec from FCP?
    Deborah
    Arnie Schlissel replied 16 years, 6 months ago 3 Members · 2 Replies
  • Mark Spencer
    March 7, 2010 at 8:45 pm
    The interlace problems weren’t apparent in FCP because FCP’s Canvas by default only shows you one field, while Motion shows you both fields.
    But there is no reason to go to Motion to stabilize a shot, since FCP has the Smoothcam filter, which does exactly the same thing.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Arnie Schlissel
    March 8, 2010 at 5:18 am
    You will have the same exact interlacing problems if you try to stabilize the footage in FCP.
    Stabilizers work by shifting the image around to compensate for the motion of the camera. If it senses the camera moving up, the clip is shifted down, camera left, clip right, etc. All stabilizers work this way.
    If you shift the clip up or down, you will reverse fields. That’s why the FCP manual warns against stabilizing interlaced material.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
