Activity Forums Apple Final Cut Pro Legacy Final Cut Pro Renders
  • Final Cut Pro Renders
    Posted by David Woodward on June 16, 2005 at 8:55 pm
    I am a relative newbie to FCP having migrated from Composer. I have a 12 minute video with 4 video streams that the time line says needs to be rendered. And the screen says its unrendered when one plays through. When I go to render FCP acts as if there is nothing to render, even though the ominous red lines are still in the time line.
    What to do? What to do?
    David Woodward replied 21 years, 3 months ago 2 Members · 2 Replies
  • Gunner Jones
    June 16, 2005 at 9:01 pm
    Go to your Sequence>Render Menus and Check all the qualities that you want to be rendered. Otherwise, nothing will happen. I suggest checking the Red Render bar, Light Green Preview bar and Dark Green Full bars.
    O&O-Gunner Productions
    FCP-Avid-After Effects
  • David Woodward
    June 16, 2005 at 9:14 pm
    Gunner:
    Thanks much. I’m a moron. This is a great resource. I’m adapting to FCP and at times its a rocky road. Similar to the rocks I have in my head. Again, thanks for your help.
    David Woodward
