Activity › Forums › Apple Final Cut Pro Legacy › Final Cut Pro rendering
  • Final Cut Pro rendering
    Posted by Lisa Wilkie on October 17, 2011 at 4:47 pm
    I’m working on a video portfolio of my sisters acting. Some files are .dv others are .mov.
    Every time I try to render, I get a message saying theres insufficient memory and to clear out the render manager, yet its empty.
    The file is 4.4MB
    Lisa Wilkie replied 14 years, 11 months ago 4 Members · 10 Replies
  • 10 Replies
  • Rafael Amador
    October 17, 2011 at 5:10 pm
    Hi Lisa,
    You would go better by re-wrapping the “.dv’ files.
    With MPGstreamclip just need to “Save as..QT”.
    rafael
    http://www.nagavideo.com
  • Lisa Wilkie
    October 17, 2011 at 5:34 pm
    I changed the .dv’s to .mov’s but am still having the same problem
    :s
  • Chris Tompkins
    October 17, 2011 at 5:55 pm
    Can you give us the specs on the clip?
    Did you:
    Repair permissions
    Trash Prefs
    reboot
    relaunch?
    Chris Tompkins
    Video Atlanta LLC
  • Lisa Wilkie
    October 17, 2011 at 6:02 pm
    What kind of specs? (Sorry, im not great at the very technical side of things.)
    I’ve relaunched FCP, and now have a ‘additional render files’ folder in the Render Manager.
    Hope that helps.. :/
  • Chris Tompkins
    October 17, 2011 at 6:10 pm
    Size? 720×480
    Codec? Prores? DVCPRO?
    Frame Rate?
    Interlaced?
    What did you change it to?
    Chris Tompkins
    Video Atlanta LLC
  • Lisa Wilkie
    October 17, 2011 at 6:20 pm
    I looked at three different clips and got this, sorry its not more.
    Size? 960×720/ 156.2MB/ 282.1 MB
    DVCPRO HD 720p50/ Dv/DVCPRO -NTSC/DV-PAL
    Frame Rate? 25fps/ 29.97 fps/25 fps
    All play on QuickTime
  • Chris Tompkins
    October 17, 2011 at 6:51 pm
    Which is the dominate format? Which sequence settings?
    Chris Tompkins
    Video Atlanta LLC
  • Lisa Wilkie
    October 17, 2011 at 7:23 pm
    most of the clips DVCPRO HD 720p50 and DV/DVCPRO-NTSC
    Sequence preset is DV NTSC 48 KHz
  • Bret Williams
    October 17, 2011 at 9:14 pm
    It appears that her scratch disk is full. That’s when FCP tells you to clear out with the render manager. That doesn’t mean that clearing out with the render manager is going to do anything. If you haven’t rendered anything yet, then of course it’s not.
    Lisa check in your scratch disk prefs where the renders are set to go, and if there’s enough drive space there.
    Then there’s the mess of formats and frame rates you’re mixing.
  • Lisa Wilkie
    October 17, 2011 at 9:25 pm
    I know x.x Im more used to downloading from a camera through a mini DV then using a harddrive.
    It saids i have 100 MB of minimum allowed free space on the disk. And by all the ticks it says 44.4 MB on FCP
