Activity › Forums › Apple Final Cut Pro Legacy › final cut pro / rebel t2i / 1080p question
  • final cut pro / rebel t2i / 1080p question
    Posted by Justin Blaney on December 31, 2010 at 5:31 am
    I’m filming on a rebel t2i at 1080p and bringing it into Final Cut Pro 7 on a mac pro 10.6 in two formats, the original format and through compressor pro res 422. My sequence settings do not allow for 1080p, only 1080i. I’ve tried setting the upper/lower/none to none, but I just want to make sure that’s how I get this to use the full 1080p. It seems like there should just be a 1080p setting. I’ve spent many hours searching this forum and others and reading books at Barnes and Noble, but haven’t found an answer. I’m sure it’s simple, but it’s escaping me. Any help you can offer would be much appreciated.
    Justin Blaney replied 15 years, 9 months ago 3 Members · 6 Replies
  • Chris Tompkins
    December 31, 2010 at 2:34 pm
    Not sure why you would bring in both formats – do not edit with the raw cam files. Converting is the way to go.
    You would use easy setup:
    1080i60
    then set the fields to none
    OR
    108030p easy setup
    and fields to none
    Then change the compressor to pro-res if that is what your files are.
    Or, drag a imported movie file onto a new comp and let FCP change the comp to match. But if you shot progressive then change the fields setting to none.
    Back up cam card files always.
    Chris Tompkins
    Video Atlanta LLC
  • Justin Blaney
    December 31, 2010 at 6:24 pm
    Thanks! I wasn’t bring it in both formats at the same time, I was origianlly using the T2i original format, then I learned that it would be better to switch to pro res 422 but even after I tried that it was still having the 1080i problem.
    A couple more questions, if you don’t mind.
    When it says 1080i, but the field dominance is set to none is that really progressive?
    Why are you recommending 1080i60 or 1080p30? If I shoot in 1080p30, isn’t that the only one I should use?
    Do you recommend using compressor to change to prores 422 from the native format? Or using FCP (I’ve heard that you can convert in FCP with log and transfer, but I haven’t used that feature)
    Since you’re recommending DVCPRO for the easy setup, should I just use that for the converted format instead of prores 422?
    Thanks in advance for your help!
  • Chris Tompkins
    December 31, 2010 at 7:24 pm
    Your original post did not indicate the “30” so I was assuming between those 2 1080P’s
    Yes.
    T2i import plugin for FCP:
    https://thebuibrothers.com/blog/2010/03/how-to-canon-t2i-with-eos-movie-plugin-e1-final-cut-pro/
    Not sure. Someone else?
    Chris Tompkins
    Video Atlanta LLC
  • Steve Eisen
    December 31, 2010 at 7:27 pm
    Use Log and Transfer. Google to get the T2i hack.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Justin Blaney
    January 1, 2011 at 7:56 pm
  • Justin Blaney
    January 1, 2011 at 7:57 pm
