Activity Forums Apple Final Cut Pro Legacy Final Cut Pro question
  • Final Cut Pro question
    Posted by Jonathan Peragine on January 14, 2009 at 8:29 pm
    I shot a video with a computer monitor in one of the clips. The monitor is not lit (I had no plug for it). I would like to light the monitor screen now. I have tried a lens flair effect in Final Cut, but is doesn’t look that great. Any suggestions, other then reshooting the scene?
    Wes Koetje replied 17 years, 8 months ago 2 Members · 3 Replies
  • Wes Koetje
    January 14, 2009 at 9:23 pm
    Have you tried garbage matting a still image?
    Maybe with a glow filter you may get the effect you are wanting
    Good Luck
  • Jonathan Peragine
    January 14, 2009 at 9:46 pm
    Can you explain garbage matting?
  • Wes Koetje
    January 15, 2009 at 1:11 am
    Place your image in a new layer, add either (4-point garbage matte) filter or (8-point garbage matte) to the image. Then adjust the corner points to fit the shape of the computer monitor.
    Hope that helps
    -wes
