Activity › Forums › Apple Final Cut Pro Legacy › Final Cut Pro Quality Loss… Please Help
  • Final Cut Pro Quality Loss… Please Help
    Posted by Artticus on July 7, 2006 at 11:57 pm
    Hi, I learned FCP 3 on my own and now it’s doing some weird stuff.
    Im using Very Good Pictures and HD video off of one of the best cameras on the maket but when i go to edit video and Compile a movie It seems that the pictures are losing quality and they start to look fuzzy (this is after i render it).
    I have my render setting on HI Quality with No Compression and it still is giving me poor quality. But before i render it it looks Great. I have done many movies before and have not had this problem but i just can’t seem to figure this out.
    Im on a Mac is that matters.
    Please help,
    Josh T
    joshua@servingourworld.org
    http://www.ServingOurWorld.org
    Artticus replied 20 years, 3 months ago 2 Members · 2 Replies
  • Kevin Monahan
    July 8, 2006 at 3:31 am
    [Artticus] “Hi, I learned FCP 3 on my own and now it’s doing some weird stuff.
    Im on a Mac is that matters.”
    Josh,
    Of course you’re on a Mac if you’re on FCP. The pictures look fuzzy because you need to monitor your footage through a video monitor NOT the computer monitor. The computer monitor does not show you the true quality of your video.
    And if you’re playing around with HD, you’ll need a video capture card to do that. You should not compress with the None Compressor, as that is merely for intermediate renders and never for playback and editing.
    FCP 3 is a bit different in the way it displays video on the Canvas and it’s caused massive confusion for self-taught newbies like yourself. Keep pluggin’ away and save up for an Apple Certified Class. You’d be amazed with you don’t know. 😉
    Kevin Monahan
    Take My FCP Master’s Workshop!
    fcpworld.com
    Pres. SF Cutters
  • Artticus
    July 8, 2006 at 3:35 am
    Thanks so much for the help.
    What compressor should i use?
    Josh
