Activity › Forums › Panasonic Cameras › Final Cut Pro Project/Sequence Settings
William Speruzzi replied 20 years ago 5 Members · 15 Replies
William Speruzzi
September 20, 2006 at 4:51 pmOkay so I think I’m set here. This is the workflow I’m looking at:
Footage is shot in 1080/24pA mode, transfered on site to a Firewire drive. Those MXF will be imported into my FCP 5.1 system, converted to Quicktime files remaining on 23.98p. Edit on a 24 timeline by setting up with a 1080i DVCPRO HD preset> altering the timebase to 23.98> Edit!
When the MXF files are transfered to a Firewire drive will they automatically be kept as 23.98 or is there a setting to transfer the footage at various frame rates? What I want to know is do I need to tell the DP to keep it at 23.98 when he transfers?
Re: Monitoring. I’m just going to have to make do with what I have (check my profile to see my gear). I have an older DP 2.0 G5 that isn’t PCI-x/PCIe ready so getting a decent HD capture card isn’t really an option. I’d buy a AJA or Decklink card tomorrow but my G5 doesn’t have the right PCI slots to accommodate.
william speruzzi
[digital post-production]
https://www.williamsperuzzi.com/
info@williamsperuzzi.com -
Uli Plank
September 21, 2006 at 7:06 amIf you want to stay machine independent (regarding card slots) for monitoring, have a look a t the Matrox MXO.
Regards,
Uli
Author of “DVDs gestalten und produzieren”, a book on professional DVD-authoring in German.
William Speruzzi
September 23, 2006 at 9:26 pmShane,
What format was the master you layed back to?
william speruzzi
Shane Ross
September 23, 2006 at 10:11 pmWe output to HDCAM, 1080p 23.98. And we were going to deliver HDCAM Texted Closed Captioned masters to the network, but found that HDCAM tapes have trouble accepting a Closed Caption feed. So we ended up delivering D5 to the network, which accepts the CC file just fine.
Shane
Littlefrog Post
http://www.lfhd.net -
William Speruzzi
September 24, 2006 at 7:24 pmI was looking at HDCAM too. Good to know about the CC.
william speruzzi
