Activity Forums Apple Final Cut Pro Legacy Final Cut Pro project settings
  • Final Cut Pro project settings
    Posted by Razamataz on July 28, 2006 at 10:12 am
    I have recently started using final cut pro and was wondering if anyone could recommend what project settings to use when creating a new project. I am using a kona LHe and most of my footage is dv. I am trying to find the best way to configure the project settings so that I can get real time previews and an external monitor preview out of my kona. Everything I capture using kona settings forces everything to be rendered. Is there any way around this?
    Arnie Schlissel replied 20 years, 1 month ago 3 Members · 2 Replies
  • David Bogie
    July 28, 2006 at 8:12 pm
    Certainly the Kona manual came with instructions on how to set up your projects?
    There’s a Kona Web site and there’s a Kona forum here on the cow, I think.
    bogiesan
  • Arnie Schlissel
    July 29, 2006 at 4:03 pm
    [razamataz] “I have recently started using final cut pro and was wondering if anyone could recommend what project settings to use when creating a new project.”
    Without meaning to be crass, you should use project settings that are appropriate to the project. If you’re working with DV, use DV settings. If the next project is 8 bit, use 8 bit. It may vary from project to project, and many projects go through an offline phase, followed by an online where the settings change.
    Arnie
    Now in preproduction: Peristroika (Cosmological Congress), a film by Slava Tsukerman
    https://www.arniepix.com
