Activity › Forums › Apple Final Cut Pro Legacy › Final Cut Pro – Problem exporting XML of Sequence “Critical Error”
Posted by Leigh O’neill on January 25, 2012 at 7:11 pmHi there,
I’m fairly new to Final Cut. I’m trying to export an XML of our picture locked sequence for finishing/color timing. Every time I try, I get “xml translation was aborted due to a critical error” about 20% in. The sequence is ProRes HD 4:2:2, about 1Hr 30Min. I’ve read of people having problems with XML while exporting large projects (over 50mb) but this is just a single sequence. Any ideas?
Thanks!Leigh O’neill replied 14 years, 7 months ago 3 Members · 5 Replies -
David Roth weiss
January 25, 2012 at 7:17 pmDo you have any events (clips) disabled in the timeline?
Any clips that have no reel numbers?
Clips named “untitled”?
The list goes on… But, you get the picture. Right?
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los Angeles
https://www.drwfilms.comDon’t miss my new Creative Cow Podcast: Bringing “The Whale” to the Big Screen:
https://library.creativecow.net/weiss_roth_david/Podcast-Series-2-MikeParfitandSuzanneChisholm/1POST-PRODUCTION WITHOUT THE USUAL INSANITY ™
Creative COW contributing editor and a forum host of the Business & Marketing and Apple Final Cut Pro forums.
Jerry Hofmann
January 25, 2012 at 7:21 pmSounds to me like about 20% into your sequence, you have some media files that are corrupt. Re build this area and give it another go. If the media file is really corrupt, you need to rebuild it by exporting it as a self contained movie file using the same codec as before, but turn on recompress all frames… but I’ll bet that’s the problem.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
Leigh O’neill
January 25, 2012 at 7:21 pmI’m just coming on to the project so I’m not too sure, I’ll scour through and get back to you. Much appreciated!
Leigh O’neill
January 25, 2012 at 10:19 pmThanks Jerry, I’ll take a look at doing that. I’m now getting the error at around 9%, it seems to vary at what point it crashes.
As for the clip names, reel numbers…
Do Text layers, slugs..that type of thing need reel numbers?
No clips disabled or “untitled”.
Thanks guys! -
Leigh O’neill
January 25, 2012 at 11:55 pmJeez, nothing seems to work. Taken the sequence into a new project, copied its contents into a new sequence, took everything offline, tried it in separate parts. Even if I delete the first quarter of the sequence it still comes up with the error around 14%, sometimes 9% and sometimes 20%.
Very frustrating…
