Activity Forums Apple Final Cut Pro Legacy Final Cut Pro playback issue
  • Final Cut Pro playback issue
    Posted by Michael Jones on March 3, 2011 at 8:16 pm
    When I play back my sequence, the playhead doesn’t move until I stop playback, then it jumps to the position in the sequence where I stopped. I also noticed when I moved a keyframe to change a motion parameter, the visual tracking line in the canvas didn’t reflect my change (the new motion was correct) until I stopped playback. I have 6 GB 667 MHz DDr2 FB-DIMM. I do have a few other applications open but they’re not running any processeing (iCal, MacMail, Safari). Is this an issue of RAM?
    Michael Jones replied 15 years, 5 months ago 2 Members · 2 Replies
  • Steve Eisen
    March 3, 2011 at 9:00 pm
    We can only guess unless you give us all your settings and hardware specs. Sequence settings, codec, system, etc…
    Definitely not a RAM issue.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Michael Jones
    March 8, 2011 at 3:47 pm
    Sorry for not getting back sooner. I ran Verify Permissions and all checked out OK, but I don’t seem to have the issue anymore. Here’s all the specs:
    Sequence:
    720×480 NTSC DV (3:2)
    PAR: NTSC CCIR 601/DV (720×480)
    Lower (Even)
    DV/DVCPRO – NTSC
    Render in 8-bit YUV
    Hardware:
    MacPro Dual-Core Intel Xeon
    2.66 Ghz
    2 Processor, 4 core
    6 GB memory
    L2 Cache per processor, 4 MB
    I recently downloaded a After Effects CS5 trial and the problem started soon thereafter..?
