Activity Forums Apple Final Cut Pro Legacy Final Cut Pro on Mac Mini
  • Final Cut Pro on Mac Mini
    Posted by Leary_shane on June 6, 2007 at 7:28 pm
    I just recently added Final Cut Pro onto my Mac Mini and I am currently trying to capture footage. The footage that I tried capturing would be choppy, slow, and jumpy and sometimes would say “dropped frames,” but when I used iMovie HD to capture the same footaged, it worked perfectly. Do you guys think that my Mac Mini can’t support Final Cut Pro 5?
    Howard Matthews replied 17 years, 9 months ago 5 Members · 6 Replies
  • Walter Biscardi
    June 6, 2007 at 8:42 pm
    Are you using an external media drive or the internal? You can’t capture to the internal drive.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Leary_shane
    June 6, 2007 at 9:54 pm
    I’m using an external drive with 215 GB.
  • 13 Create COW Profile Image
    13
    June 7, 2007 at 4:11 am
    Is the eternal drive USB or Firewire, NEVER use USB for video editing.
  • Leary_shane
    June 7, 2007 at 12:23 pm
    It is actually set up in a wireless external drive in my network. So what I need is to use an external hard drive that uses firewire?
  • Richard Martz
    June 7, 2007 at 3:48 pm
    Duh. Yep. Use the Firewire Luke!
    Richard Martz
    MagicMartz Media
    Final Cut Pro HD
    Kona LH
    After Effects
    PhotoShop
    Illustrator
    Lots of other Fun Stuff!
  • Howard Matthews
    November 24, 2008 at 2:39 pm
    Re. USB drives – I have to report that I’ve had no problems editing some pretty big and complex projects on my Mac Mini using only USB-2 drives.
    I had problems originally trying to capture from a FW source (camcorder) to a FW drive, probably because there’s only one FW socket on the mini so you have to daisy-chain the devices. All the data has to come down and go up the same wire, not good.
    So long as it’s a decent drive, USB-2 is perfectly usable for video.
