Activity Forums Apple Final Cut Pro Legacy final Cut Pro Multiclip Color Correction Question?
  • final Cut Pro Multiclip Color Correction Question?
    Posted by Gregman on January 22, 2007 at 2:27 am
    I compiled 6 camera angles into a multiclip in Final Cut pro 5.1 and I am done making my edits. Now, I want to lay a different color correction effect
    into each of the 6 angles. My question: is there some way to add a filter to each of the 6 maser angles, so I don’t have to go clip-by-clip to add the filters?
    Basically, I want to only have to add the filter to the first frame of each 6 angles and have that filter automatically apply to each cut from that particular angle.
    I know I can do this before I begin my edit, but I want to do it afterward instead. Is this possible?
    Greg
    George Bazhenov replied 18 years, 7 months ago 3 Members · 2 Replies
  • Shane Ross
    January 22, 2007 at 3:34 am
  • George Bazhenov
    January 24, 2008 at 6:49 am
    Shane’s link has gone bad. Does anyone know where I can find this material? Alternatively, can someone please explain how to apply a filter to all cuts of an active angle? I ran into a problem applying a filter to an angle of a multiclip that is already on the timeline. The technique described in the manual does not work – effects get applied only to one instance of the active angle, not to all cuts of the angle. Or am I dreaming and expecting to get too much?
    George Bazhenov
    Apple Certified Trainer, Final Cut Pro
    https://video.naveki.org
