Activity Forums Apple Final Cut Pro Legacy Final Cut Pro Mov Audio Problem
  • Final Cut Pro Mov Audio Problem
    Posted by Arahman Sa on March 2, 2011 at 1:06 pm
    I’m having an issue with audio on FCP. I’ve converted a VRO file (from my video camera) into a .MOV using MPEG Streamclip and while I opened it on FCP, I’ve noticed that the audio comes a little late.
    Does anyone know why this problem is and if there is any way I could fix it?
    I’ve tried to convert the video to MPEG but no audio is heard with that format on FCP either. Which is the best format to work with on FCP any way?
    Thanks a lot!
    John Vonmutius replied 15 years, 6 months ago 2 Members · 1 Reply
  • John Vonmutius
    March 2, 2011 at 8:01 pm
    MOV is not a codec, it’s just a file container. What codec did you use when you converted the VRO?
    Exploring the pitfalls of the 5D workflow. The many, many pitfalls…
