Final Cut Pro – Masking area in green or blue screen
Although in theory this shouldn’t happen… It has happened!
We were rushed in a shoot and had to change our usual green screen back ground to a blue one.
Unfortunately our presenter was wearing a light blue tie.
Although the tie is a much lighter shade of blue it is obviously getting keyed out along with the back ground.
Is there a way we could put a mask over the subjects mid section (Tie) that would then eliminate the Key filter in this area?
At this stage, I have put a solid color behind the presenter which does make it look a little better however is not exactly ideal.
Thanks in advance!
