Activity › Forums › Apple Final Cut Pro Legacy › Final Cut Pro: Lost communication with my AJA io box
  • Final Cut Pro: Lost communication with my AJA io box
    Posted by David Ashley on September 26, 2007 at 8:54 am
    Hello,
    I seem to have lost all communication between My Final Cut Pro and my AJA io box. I cant seem to capture anything. All my presets are all correct and all cables are connected. My AJA ProIO Control Panel also tells me I have Video Present but Final Cut wont pick anything else up. I had a similar problem when I downloaded the last apple OSX update and did download an update a few days ago. Can anybody help?
    Chris Poisson replied 19 years ago 3 Members · 3 Replies
  • Gary Adcock
    September 26, 2007 at 11:02 am
    [Dashley] “I seem to have lost all communication between My Final Cut Pro and my AJA io box”
    Without info on your system
    check 3 things first.
    1) that you have no other FW devices attached, the Io wants the entire FW bus.
    2) that you have uninstalled then reinstalled the ioDriver.
    3) checked to make sure that your easy set up is correct.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
  • David Ashley
    September 26, 2007 at 12:11 pm
    Hello,
    Thanks for the pointers. I have done everything you have suggested but I still not having any luck.
    I have recently updated to OSX 10.4.10 and also updated quicktime to 7.2. Do you think this could be something to do with the problem?
  • Chris Poisson
    September 26, 2007 at 2:54 pm
    I don’t have an iO, but my AJA Kona LH sometimes goes away, about every two months or so, when this happens I just unplug everything and put it all back, and also repair permissions and run Disk Warrior on everything. Seems to work…
    Have a wonderful day.
