Activity Forums Apple Final Cut Pro Legacy Final Cut Pro keeps quitting unexpectedly on launch cause by CSR Hall plug-in
  • Final Cut Pro keeps quitting unexpectedly on launch cause by CSR Hall plug-in
    Posted by Linh Phan on September 13, 2010 at 2:12 pm
    My Final Cut Pro keeps quitting unexpectedly on launch cause by CSR Hall plug-in. I don’t know what it is, and I don’t know how to solve this problem. It worked before, then that happened, so I uninstalled FCP then I re-installed it, and the problem is still there.
    Rafael Amador replied 15 years, 11 months ago 3 Members · 5 Replies
  • Peter Wiggins
    September 13, 2010 at 3:14 pm
    Are you running a music composing piece of software like Logic etc? A quick Google leads me to believe that FCP might mistakingly be trying to install that plugin.
    If so, do a spotlight search for it and remove it to another location.
    Peter
  • Linh Phan
    September 13, 2010 at 3:24 pm
    Thanks Peter,
    However, I don’t run any music composing software. I do have Protool and MBox on my Mac, but I don’t run it while I’m running FCP. I don’t know if that still affects…
  • Rafael Amador
    September 13, 2010 at 4:20 pm
    That sounds to some internal FC Plugin.
    Probably FC is unable to find it or load it.
    Those are the typical things that happens when your system needs some maintenance: repair Permissions and run an application to rebuild your system (and HDs0 directories.
    rafael
    http://www.nagavideo.com
  • Linh Phan
    September 13, 2010 at 5:43 pm
    I found out that since I installed Protools, it contains IK Multimedia CSR Hall Plugin. I couldn’t locate that plugin, and that caused FCP crashed. I don’t know how to stop FCP running that plugin… 🙁
  • Rafael Amador
    September 14, 2010 at 3:27 am
    Then you need to make a clean un-install of ProTools.
    rafael
