Activity › Forums › Apple Final Cut Pro Legacy › Final Cut Pro Interface Disapears
  • Final Cut Pro Interface Disapears
    Posted by Stephen Connolly on March 16, 2008 at 12:51 am
    I am having an issue with my Final Cut Pro Interface disappearing. If I hide FCP or play a clip. It randomly disappears except a ghosted outline of the video display window and the tools. I tried re-installing FCP, re-installing the OS, trashing preferences, and rebooting. The only way to get it back is if I log out of the OS, and back in (same user). Has anybody experienced this or heard of this? Any help would be appreciated.
    I am running:
    FCP 6.0.2
    MAC OS 10.5.2
    BlackMagic Intensity Pro
    Stephen Connolly replied 18 years, 6 months ago 2 Members · 2 Replies
  • Andy Mees
    March 16, 2008 at 7:26 am
    sounds like you are having trouble with Expose/Spaces getting in the way of FCP’s function keys causing your application windows to hide, rearrange, disappear off into other “spaces” etc etc
    I always recommend FCP users remap Expose/Spaces/Dashboard to less obtrusive keys, as the default settings tend to clash with primary FCP edit keys
    you can remap your keys in the OS System Preferences >> Expose & Spaces pane
    if necessary, you can also disable “spaces” there too
  • Stephen Connolly
    March 16, 2008 at 1:15 pm
    Thanks for the tip. Unfortunately, that can’t be the case. I don’t use spaces, and it is not enabled.
