Activity › Forums › Apple Final Cut Pro Legacy › Final Cut Pro inserts wonky timecode
Posted by Jared Lorenz on November 9, 2009 at 7:34 pmHi,
I am editing to tape on FCP 6 using a Matrox MXO2 connected to a Mac pro 2×4-core 2.8ghz with 10gb of RAM and running 10.5.8.
This issue has popped up on another machine connected to an AJA IO HD so I am fairly sure it is not dependent on hardware.
When I go to stripe / black and code the tape, FCP insists on replacing 58:00:00 with 46:24;24. If I paste anything in it replaces it with another set of random numbers. It also insists that my NDF 23.98 settings should be laying down DF timecode.
Any ideas on how to get this to work (properly)? It’s sort of urgent.
Jared Lorenz replied 16 years, 10 months ago 4 Members · 16 Replies -
Jared Lorenz
November 9, 2009 at 8:16 pmIt’s a HDCam tape inside of a HDWF500, connected to a Matrox MX02, RS422 Sony 23.98 deck control,
Jared Lorenz
November 9, 2009 at 8:38 pmFor real. Someone must have had this issue before and can help me. I am ready to chew my arm off here. Help. Please. Help.
Jeremy Garchow
November 9, 2009 at 8:40 pmAnd your deck is setup for 23.98 psf? Where is the deck set to grab tc from? Why Black and code from FCP? Why not just use the deck and do a little stripe, then use FCP to assemble from an hour, or whatever you need?
Jeremy
Jared Lorenz
November 9, 2009 at 9:02 pmHi Jeremy,
I can stripe just using the deck but it doesn’t solve the issue with FCP.
The other problem with using the deck alone is that when I stripe using the deck I am not getting matching VITC and LTC even though TCG is set to follow LTC. That will trigger a rejection.I’ve called the deck house, the configuration on the deck is correct for VITC to follow LTC but it’s not working.
These machines make me feel stupid.
Shane Ross
November 9, 2009 at 9:16 pmOK…I had this issue. When I had a PAL sequence setting and EASY SETUP (I forgot to switch back to NTSC ProRes 1080i) I would type in a number and a completely different one would appear. So…make sure that your Easy Setup is set proper to match what you are outputting, and that your VIEW>EXTERNAL is also set to match what you are outputting. Same frame rate…
Shane
Read my blog, Little Frog in High Def -
Jeremy Garchow
November 9, 2009 at 9:19 pm[Jared Lorenz] “These machines make me feel stupid.”
🙂 No worries.
As for FCP, my instinct is that something isn’t setup properly for you in the deck.
Jeremy
Jared Lorenz
November 9, 2009 at 9:38 pmI have seen that too and in this case everything matches (easy setup, deck control, etc).
So here’s an interesting set of facts – perhaps related.
The deck panel displays timecode as 24 frame timecode.
FCP is set up for Deck control 23.98 Sony RS422
However when I use deck control to jog/shuttle through the tape via FCP, the timecode display in final cut is giving me 29.97 timecode.
The panel reads 58:02:08; Final Cut ETT window reads 58:05:26Timecode convert in the deck is set to OFF
Timecode read is set to OFF TAPEI pray to the deck gods to send me an answer.
Jared Lorenz
November 9, 2009 at 9:38 pmSee my response to Shane above with relevant deck settings.
Jared
Jared Lorenz
November 9, 2009 at 10:17 pmHere is something else interesting.
The MXO2 doesn’t come with a 23.98 deck control preset. I’m going to hop over to the Matrox forum and see if that has something to do with it. Maybe it’s just not supported.
Still doesn’t explain the mismatched timecode on the deck, but that’s a whole other issue.
