Activity › Forums › Apple Final Cut Pro Legacy › Final Cut Pro Horizontal Lines through my video.
Posted by John Deckling on February 26, 2012 at 8:12 pmHey, i have the horizontal lines through my video once i dump the video into the timeline. I’ve tried de-interlacing it, but it doesn’t do anything and sometimes just makes them worse. I make gaming videos, and record with a capture card. I’m a noob with final cut but i know the basics. Please help!!
Heres one of my videos for proof- https://www.youtube.com/watch?v=Joyv4Iye5nQJohn Deckling replied 14 years, 7 months ago 3 Members · 9 Replies -
Jerry Hofmann
February 26, 2012 at 11:40 pmWhat format are you capturing to? Looks a bit like a wrong field dominance problem.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
John Deckling
February 26, 2012 at 11:44 pmyea someone else said that. I’m capturing with H.264 i think how do i check?
Jerry Hofmann
February 27, 2012 at 12:23 amDon’t capture to H.264, it’s not supported in FCP for editing. It’s a delivery format.
Capture to ProRes instead. ProRes 4:2:2 or ProRes HQ might fix you right up.
Jerry
Current DVD:
John Deckling
February 27, 2012 at 12:44 amhmm i tried apple pro res and it didn’t work. I tried all of the pro res. Wait so your talking about the sequence settings right?? I’m changing the compressor from h.264 to apple prores 422 and it doesnt work. Thanks for helping
Jerry Hofmann
February 27, 2012 at 2:18 amTry transcoding the H.264 you have captured to ProRes, put it in a sequence matching it’s settings, then see if the result isn’t better.
How are you connecting from your game box to the computer?
Jerry
Current DVD:
John Deckling
February 27, 2012 at 2:28 amThat what i was doing before i think. It gets worse at first then when add the de-interlace effect using the upper(odd) it gets better. But when i do the even it gets worse. Hmmm I dont see what you mean by transcode it. I went to sequence settings and changed the sequence compressor to apple pro res 422, if thats what you mean by transcoding it.
Jerry Hofmann
February 27, 2012 at 3:07 amI mean you should take a clip that’s h.264 now, and export it as proves. Then import that proves version of your file and see if the problem doesn’t go away when you put it in a sequence matching it’s settings. Your problem may well be the fact that FCP does not in any way support h.264 editing. You have to make the source become ProRes before you edit it.
Jerry
Current DVD:
Steve Eisen
February 27, 2012 at 4:10 amTo do what Jerry suggests, drag your h.264’s into Compressor and choose ProRes setting hit submit. Drag the new ProRes file/s into FCP and hit yes.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Final Cut Pro Users Group -
John Deckling
February 27, 2012 at 11:01 pmThanks someone else suggested that! I wen’t to the igrabber video settings and changed the compressor to pro ress and the lines dissapeared 😀 thanks so much!
