Activity › Forums › Apple Final Cut Pro Legacy › Final Cut Pro. HDV to Web H.264 Compression
  • Final Cut Pro. HDV to Web H.264 Compression
    Posted by Steve Hudson on August 13, 2010 at 4:49 am
    Hi there,
    I’ve been on the forum a fair amount, but this is my first post.
    I’m wanting to send several separate short (30 second to 120 second) FCP sequences to compressor and have them playable on a website. The sequences are in two separate projects, one HDV 1080i 50i (PAL) and the other 1080i 60i (NTSC).
    I know I want a finished H.264 codec for the web, but would like to confirm the best SETTINGS in the drop down tabs to get the preferred result, obviously I will lose a large amount of quality from the original capture but still would like to keep enough in the images and audio so its decent to view on the website. Would like all finished videos to remain 16:9
    Compressor:
    I’m particularly interested in the Inspector Window and the following “Resizing Control” settings:
    Resize Filter
    Output Filter
    Deinterlace
    What is best to set these too?
    Also, what setting should I use for the Rate Conversation at the bottom of the Inspector? Am I missing anything?
    Platform I’m running:
    MacBook Pro 2.93 GHz Core 2 Duo
    Snow Leopard 10.6.4
    FCP 7.0.2 (latest Final Cut Studio)
    Conpressor: 3.5.2
    Many thanks for your input, much appreciated.
    LS
    Steve Hudson replied 16 years, 1 month ago 2 Members · 2 Replies
