Activity Forums Apple Final Cut Pro Legacy Final cut pro HD render HELP
  • Final cut pro HD render HELP
    Posted by Shearerbrilliance on March 4, 2007 at 1:15 am
    After editing my video i was ready to export the video to dvd. When i would watch the DVD in the player the some clips would jump (like a strobe effect). The video plays fine in the time line. I even tried putting the HD Sequence in a SD Sequence and letter box it. I have no idea why it is not letting me export the video. any ideas? Final cut pro HD render HELP
    Webfilms replied 19 years, 6 months ago 2 Members · 1 Reply
  • Webfilms
    March 6, 2007 at 9:21 am
    Two things, first try to export to compressor and use settings for dvd of HD dvd your choice. In this set up FCP and Compressor work on project as FCP is the sourse and Compressor scans files and converts. Tho other option is to export a QT movie at highest resolution, then use compressor to give you DVD compression and I usually select streaming video for QT 7 and let compressor make 5 steaming QT files. Hope this helps.
