Activity Forums Apple Final Cut Pro Legacy Final Cut Pro HD export Problem
  • Final Cut Pro HD export Problem
    Posted by Cory Lewis on February 28, 2012 at 6:21 pm
    I’m not sure what is going on. But, everytime I export this particular video I get issues. The audio is off and every now and then there are grey lines and cuts.
    The first try I just simple did a export with current settings and a self-contained movie and it looks the same on my computer. Then I go and try and export without self-contained and it still looks the same. It’s also darker. None of the color-correction seems to have worked.
    Here are two different exports of the same video:
    https://www.youtube.com/watch?v=1byWlaFTvSc
    Here the audio is off and no color correction:
    https://www.youtube.com/watch?v=UuCZAlV9TLg
    Glo Aurelije replied 14 years, 6 months ago 5 Members · 17 Replies
  • 17 Replies
  • Shane Ross
    February 28, 2012 at 6:32 pm
    What format are you cutting? What are the sequence settings?
    Shane
    Little Frog Post
  • Cory Lewis
    February 28, 2012 at 6:40 pm
    1920 x 1080 (16:9)
    H.269 compressor.
  • Shane Ross
    February 28, 2012 at 6:56 pm
    [Cory Lewis] “H.269 compressor.”
    BUUZZZZZZZZZ!!! Never edit H.264 in FCP. It doesn’t like that format. It’s deceptive, as it SEEMS to like it. It works intially…but after a while, errors pop up. You must convert that footage to ProRes before editing.
    If you want to edit H.264 native…use Premiere Pro.
    Shane
    Little Frog Post
  • Cory Lewis
    February 28, 2012 at 7:01 pm
    Ooookay. What does that do for my “export problem”? I already edited without any problems and have edited before in the past. (i.e. I’m not trying to scrap this 15 minute video and start over in Premiere) Only difference is this is longer. I have yet to receive an error message. Yet, its just messed up when I export.
  • Shane Ross
    February 28, 2012 at 7:07 pm
    [Cory Lewis] “What does that do for my “export problem”? “
    It points to the reason you are having export issues is due to the fact that FCP doesn’t work with H.264 well at all. You can try to Media Manage your cut to ProRes, see if that fixes it. But the reason why it isn’t working is that H.264 and FCP don’t mix.
    That is why I asked what format you are working with. Most of the time people say “I have export issues” or render issues, it is because they are working with non-FCP media.
    Try converting what you have to ProRes…again, with the Media Manager and the COPY option. Or…copy and paste into a ProRes sequence and render. That might do it.
    Shane
    Little Frog Post
  • Cory Lewis
    February 28, 2012 at 7:12 pm
    I’ll go ahead and I try it but I’m still confused though.
    Here is another video I did with the same footage (just about) and the same settings and I didn’t have this issue. Again, albeit it’s shorter.
    https://www.youtube.com/watch?v=yjDBKfF9_Co
  • Shane Ross
    February 28, 2012 at 7:39 pm
    [Cory Lewis] “I’ll go ahead and I try it but I’m still confused though.”
    Well, Apple should make it NOT work…because it is problematic.
    Shane
    Little Frog Post
  • Mark Suszko
    February 28, 2012 at 8:33 pm
    Supposedly, this is not an issue in Final Cut X, but in FCS3/ Final Cut 7, he’s right.
  • Cory Lewis
    February 28, 2012 at 8:44 pm
    Relax, it wasn’t a complaint. I just needed clarification and I got it. I’m working on fixing the problem. I’ll get back to you all if it works or not.
  • Shane Ross
    February 28, 2012 at 8:45 pm
    FIngers crossed!
    Shane
    Little Frog Post
