Activity Forums Apple Final Cut Pro Legacy Final Cut Pro HD and SD in one project.
  • Final Cut Pro HD and SD in one project.
    Posted by Javier Lopez on February 25, 2012 at 11:10 pm
    Hello,
    I am working on a project that contains HD and SD material, I have to include the SD material to an HD project, but the SD material most of it has been shooter with a pro sumer camera and cell phone, which will the best way to make this SD footage look good on a HD project?. Probably upscale the footage?.
    Thanks in advance for the help.
    Michael Gissing replied 14 years, 6 months ago 2 Members · 1 Reply
  • Michael Gissing
    February 25, 2012 at 11:42 pm
    Presuming your final is HD, upscaling is the best. You can use Compressor for this or if you have a Kona card it does and excellent real time upscale if you have a means to input the material via SDI.
    There are third party plugins in FCP that can upscale as well but I haven’t any direct experience with them. I have heard many peopleon this forum say that After Effects is a brilliant up and down scaler.
