Final Cut Pro- Frequent Timecode Breaks on Capture
I’m capturing about twenty hours of footage for an arts council, and all of the tapes appear to be damaged to a certain degree, so timecode breaks are frequent.
I’ve taken what I know to be the steps for timecode breaks, switching the capture settings from “abort” to “warn after capture”, but when I capture (both batch, clip and now), Final Cut hangs up at the first timecode break.
I rearranged the time of the clip to be past that section, but at the next timecode break it does the same thing, and so on and so forth.
Anyone know a solution to this problem?
