Activity › Forums › Apple Final Cut Pro › Final Cut Pro frames per second view or display
  • Final Cut Pro frames per second view or display
    Posted by Carlos Fraser on September 15, 2019 at 4:22 pm
    Hi guys..Does anyone here know or are familiar with Final Cut Pro enough to know if there is a setting i can check so that i can see in realtime during playback what the actual frames per second is? I know in Davinci Resolve u can see the playback fps in real time…Hoping fcpx has that same feature thanks…Would really appreciate it if anyone can point it out in fcpx thanks again
    Carlos Fraser replied 7 years ago 2 Members · 2 Replies
  • Jeff Kirkland
    September 15, 2019 at 8:27 pm
    There’s nothing that I know of. FCPX can warn you if you’re dropping frames on playback but that’s about it.
    Jeff Kirkland | Video Producer & Cinematographer
    Hobart, Tasmania | Twitter: @jeffkirkland
  • Carlos Fraser
    September 15, 2019 at 8:29 pm
    Ok thanks a lot for that information….
