Activity Forums Apple Final Cut Pro Legacy Final Cut Pro Firewire Problem?
  • Final Cut Pro Firewire Problem?
    Posted by William T on January 14, 2013 at 5:34 am
    Last week FCP6 on G-5 PwerMac stopped recognizing Firewire connection. Changed to new cable and tried with several cam-corders – still no luck. Any suggestions?
    William T replied 13 years, 7 months ago 4 Members · 7 Replies
  • 7 Replies
  • Dave Farrants
    January 14, 2013 at 8:21 am
    I had this happen with a G5, took a generic cheap 3 xFireWire input PCI card from a PC and installed it in a spare slot, worked a treat.
    Web – https://www.foxvideo.co.uk
    Blog – https://foxvidpro.blogspot.co.uk/
  • Shane Ross
    January 14, 2013 at 8:41 am
    I concur. You’ve changed the cables, and the camera…so the culprit has to be the ports. They went bad.
    Shane
    Little Frog Post
  • William T
    January 14, 2013 at 4:53 pm
    I put in a Firewire PCI hub card and connected my external hard drives. They work fine but still nothing to the cameras…. Should I reinstall FCP?
  • Alan Okey
    January 15, 2013 at 4:33 pm
    Trash your FCP preferences. It’s quite common for a corrupted preference file to be the cause of non-working FireWire in FCP.
  • William T
    January 15, 2013 at 8:07 pm
    How exactly do I trash them? Are these the preferences listed after the program is open or is a preferences folder in the system folder?
  • Alan Okey
    January 15, 2013 at 11:22 pm
  • William T
    January 16, 2013 at 4:15 pm
    Thanks. I trashed the FCP Preferences and verified hard drive- restarted and it still does not recognize the firewire.
    Bill
