Activity › Forums › Apple Final Cut Pro Legacy › Final Cut Pro Exporting difficulties
  • Final Cut Pro Exporting difficulties
    Posted by Jennifer Black on June 10, 2013 at 1:36 am
    Hi, I am trying to export a 8 minute project file from Final Cut Pro and continually get a window popping up QuikTime Error: -50. I have tried many different ways with no luck. any ideas? thanks…
    Jennifer Black replied 13 years, 3 months ago 2 Members · 5 Replies
  • Jamison Lee
    June 10, 2013 at 1:54 am
    provide more info – sequence settings, what type of footage, what type of export…
  • Jennifer Black
    June 10, 2013 at 2:00 am
    Hi, here are some more details. I have tried numerous ways, web hosting, normal export via Quicktime movie to get a different result. Here is one when I tried to export the file to H-264 – The share operation Export File has failed the operation could not be completed because an error occurred when creating frame 314 (error-1). I would be happy for any suggestions…Thanks…
  • Jennifer Black
    June 10, 2013 at 2:06 am
    Hi, here are some more details. I have tried numerous ways, web hosting, normal export via Quicktime movie to get a different result. Here is one when I tried to export the file to H-264 – The share operation Export File has failed the operation could not be completed because an error occurred when creating frame 314 (error-1). The footage is normal video fottage and alot of stills, there are quite a few transitions amoungst the stills. Could that cause the problem.
  • Jamison Lee
    June 10, 2013 at 2:43 am
    I’m a bit confused but stills can cause problems, especially if they are large or a format that
    FCP doesn’t support. Can you render the timeline at all? Try exporting a full resolution quicktime
    (no conversion) and use compressor or another utility to do the web compression. Get it “mixed down”
    to a single file, a master.
  • Jennifer Black
    June 10, 2013 at 10:23 am
    Hi, thank you for your response. In the end I duplicated the file and tried to export the new one, that one worked! So strange…the finished product is a bit jumpy tho, especially through the transitions. An suggestions? Does Compressor do a better job?
