Activity Forums Adobe After Effects Final Cut Pro export?!
  • Final Cut Pro export?!
    Posted by Luke Swain on August 15, 2007 at 3:38 am
    When I export a lossless Quicktime to be used in FCP…it works in Final Cut Pro.
    When I export what I THINK to be a lossless Quicktime to be used in AE…I get only audio, and a white screen.
    What is going on here? I have tried exporting as AppleIntermediate, DVCPRO, HDV, ANIMATION Lossless, and it cannot give me video! I am so frustrated, because I know my inexperience is probably getting in the way. I hate programs that can’t play nice with each other!
    How can I render a lossless video file from FCP, that After Effects can actually see? Please help meeee! O.o
    Luke Swain replied 19 years, 1 month ago 4 Members · 7 Replies
  • 7 Replies
  • Luke Swain
    August 15, 2007 at 3:39 am
    To clarify, the video can be seen in FCP, and on Apple computers, but when burnt to a disc and put onto my PC based AE, only the audio is seen, and the video is white.
  • Brownmarkfilms
    August 15, 2007 at 8:03 am
    How weird. I just posted nearly the exact same question, except my footage is HDV. Is yours?
  • Steve Roberts
    August 15, 2007 at 1:24 pm
    It sounds as if your Windows box doesn’t have the right codecs. Try TGA sequence or Photo-JPEG, or something else until you get something you can see. Then get back to us.
  • Luke Swain
    August 15, 2007 at 2:16 pm
    It was shot originally in HDV I believe. 1960×1440
    Targa sequence like Steve Roberts suggested. I’ll try that today.
  • Midicon
    August 15, 2007 at 2:32 pm
    Hey…
    I have seen this b4 when the version of quicktime hasn’t been updated… check that its the most current version of QT… or go to VLC (i think they have a microshaft verson ;)… you say it works in FCP… neither the export from AE or FCP is working?? then steve is right and its a codec problem and you prolly jus need to update QT….
    hope this helps
    M
  • Luke Swain
    August 15, 2007 at 3:38 pm
    Final Cut Pro can see exports from AE, but AE can’t see exports from Final Cut Pro.
    That’s a good point about the Quicktime codec. I will also try and update that.
  • Luke Swain
    August 16, 2007 at 3:22 am
    Targa sequence seems right. I can open up the individual targas, but when I try and import them into AE, I click the Targa Sequence, it recognizes the order…I hit ok…It does nothing. No processing hourglass.
