Activity Forums Apple Final Cut Pro Legacy Final Cut Pro export XML for entire project?
  • Final Cut Pro export XML for entire project?
    Posted by Joe Riggs on January 3, 2011 at 4:48 am
    I would like to import my entire final cut pro 7 project (20 bins, 10 sequences, 300+ clips) to Premiere CS5.It is very important that the structure that I have setup be maintained (bins, sequences and the clips within them) About two months a ago, I did this without a hitch..
    This time I can’t seem to get more than 1 bin and 1 sequence to export from FCP. I checked the master clips, but still 1 bin, 1 sequence.
    Help would be greatly appreciated
    Matt Lyon replied 15 years, 8 months ago 2 Members · 2 Replies
  • Joe Riggs
    January 3, 2011 at 6:40 pm
    If anyone else comes across this issue here is how you solve it. Make sure you have the browser window selected and nothing else, then export an XML.
  • Matt Lyon
    January 3, 2011 at 6:44 pm
    Did you “select all” in the browser, then export the xml?
    I just did a quick test in FCP 6.0.6 and all the bins showed up when I re-imported into FCP. I don’t have Premiere or FCP 7 to test with though…
    Matt Lyon
    Editor
    Toronto
