Activity › Forums › Apple Final Cut Pro Legacy › Final Cut Pro – export without re-encoding clips?
  • Final Cut Pro – export without re-encoding clips?
    Posted by Alexander Valys on May 11, 2008 at 1:26 am
    I have just recorded a screencast in Apple Animation format, and edited out my mistakes, swearing, etc. in Final Cut Pro. When I try to export using Apple Animation, the final file size comes out much larger than the original – I assume this is an artifact of re-encoding it.
    Is there a way to tell Final Cut Pro to export the clips without re-encoding them? They all use exactly the same settings, and play in FCP without rendering.
    If this will not work, does anyone have any other suggestions? I would prefer to use Apple Animation because of the high quality and efficiency – I would like the final output to be pixel-perfect.
    John Heagy replied 18 years, 4 months ago 6 Members · 7 Replies
  • 7 Replies
  • Jerry Hofmann
    May 11, 2008 at 3:02 pm
    File/export/quicktime movie… then select “make self contained” and use “current settings”. this will result in a non recompressed movie.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
  • Alexander Valys
    May 11, 2008 at 3:55 pm
    I’ve tried this – the final output is enormous, 6GB or so for 12-minute movie.
  • Andy Mees
    May 12, 2008 at 12:48 am
    Animation files are big Alexander … 6GB for 12 mins is not enormous, heck even at DV data rates you’d get a 3GB file.
    Are you sure you got the original recording format correct? Select one of the clips in the Browser window and press Cmd-9 to invoke the Item Properties window and report back on the Format properties listed.
  • Alexander Valys
    May 12, 2008 at 12:54 am
    The original source files, encoding using Apple Animation in iShowU, are approximately 350 MB in size, for 15 minutes.
  • John Pale
    May 12, 2008 at 1:51 am
    Are the original files using a lower quality setting of the Animation Codec (there is a slider)? Or a lower frame rate? Usually people don’t use anything but the highest setting, but its possible to lower it.
  • Dave Jenkins
    May 12, 2008 at 3:07 am
    Alexander, I have used iShowU and it does some weird things for recording video to be edited. It doesn’t record a constant frame rate. So it may be playing anywhere from 5 to 30 FPS. I use the DV50 Codec which seems to work well. I haven’t used the animation codec but DV50 exports close to the same size as the original.
    Dajen Productions
    Santa Barbara, CA
    Mac Pro 2.8 Octo – AJA Kona LHe
    Huge 1.2 Raid
    FCP 6.0.2-OS X 10.5.2-QT 7.4
  • John Heagy
    May 13, 2008 at 9:38 pm
    Make sure you have keyframing enabled and try setting it high… like 100 or more. This should reduce file size as most screen recordings are mostly static.
