Activity › Forums › Apple Final Cut Pro Legacy › Final cut pro export different then what is in timeline
Posted by Evan Clark on December 20, 2011 at 8:56 pmOkay so I just got final cut pro 7 and I wanted to make a video today. When I finished all the video work I exported it and when I played it at certain points the video is completely different then what I was seeing in the preview window in FCP. So I go into final cut and adjust the clips so that they are completely different lengths and look different when I go to play the sequence. I exported again and now it looks more like what I want, but I am pretty much flying blind now.
Jenny Calhoun replied 14 years, 9 months ago 5 Members · 10 Replies -
David Roth weiss
December 20, 2011 at 9:18 pmIt certainly sounds as if you’re editing h.264 or MP4 files. Right?
If so, now you know why there are thousands of posts here and all over the Internet advising users that they must transcode those video file types to ProRes 422 before editing.
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los Angeles
https://www.drwfilms.comDon’t miss my new Creative Cow Podcast: Bringing “The Whale” to the Big Screen:
https://library.creativecow.net/weiss_roth_david/Podcast-Series-2-MikeParfitandSuzanneChisholm/1POST-PRODUCTION WITHOUT THE USUAL INSANITY ™
Creative COW contributing editor and a forum host of the Business & Marketing and Apple Final Cut Pro forums.
Evan Clark
December 20, 2011 at 9:29 pmOkay, I have been using DVCpro. I had Express 4 so I used that since it did not support proress
Chris Tompkins
December 20, 2011 at 11:28 pmSequence settings?
Clip Settings?Chris Tompkins
Video Atlanta LLC -
Evan Clark
December 21, 2011 at 12:10 amI used to use dvcpro as the sequence and clip settings, I have it set to that in Final cut pro so I do not know why I am getting this proble.
Jenny Calhoun
December 21, 2011 at 1:34 amI have been having the exact same problem!
the video file is h.264 at 5.1 MB/secwhen i export it for quicktime movie or use quicktime conversion, the video footage gets completely out of order.
i see David Weiss’s post about “transcode those video file types to ProRes 422”, but is that “all”? and can i do this to an entire batch of footage at once? i’ve got 50 gigs that will all need to be transcoded.
i have experience with editing, but all of the CO/DEC stuff really baffles me.
David could you please provide a link that you think has the best solution for transcoding?thank you so much,
from a film student who was not taught about codecs 🙁 -
Chris Tompkins
December 21, 2011 at 1:20 pmJust to make clear….
You dropped a DV-NTSC clip into a blank sequence and FCP made a match?
Have you tried exporting using “Current Settings”
Making self-contained clip?Chris Tompkins
Video Atlanta LLC -
Evan Clark
December 21, 2011 at 2:39 pmThe sequence settings are set a dvc/dvpro ntsc. I have never had this problem before.
Jenny Calhoun
December 21, 2011 at 7:38 pmok, so i drop the files onto compressor and apply a quicktime setting it looks like.
thanks so much for the info about h.264… wasnt my camera, i just thought the files would be good to go.
