Activity › Forums › Apple Final Cut Pro Legacy › Final Cut Pro EDL Export Problem
  • Final Cut Pro EDL Export Problem
    Posted by Omer Ozcan on December 6, 2011 at 1:26 pm
    Hello,
    I am trying to get an edl of my movie. when i export edl, it appears everything is correct except the ends of clips are one frame more than original. how can i fix it?
    thank you.
    Andrew Rendell replied 14 years, 9 months ago 2 Members · 1 Reply
  • Andrew Rendell
    December 6, 2011 at 1:45 pm
    It could be that you’re misreading the edl. The convention for edl’s is that the IN point is the first frame recorded on the “master tape” and the OUT point is the first frame not recorded, so each edit will have the same number in the OUT point as the IN point for the next edit.
