Final Cut Pro – Edit to tape accuracy – does it exist?
It seems like the only way I can get edit-to-tape (RS422/KONA LH) to hit the mark is to offset my program start time in the sequence. It doesn’t seem like the device control offset settings are able to make it happen.
I’ve tried every possible incremental change in the device control panel (both capture and playback offsets) – and mastering on the UVW1800 without accuracy is the result.
I finally settled on moving all my clips down two frames in the sequence.
I have an HDSR and a DigiBeta deck in on the weekend…what wonders await me on these!
I had trouble getting the AJAio to do the same a month ago when mastering to DigiBeta – what a pain for just one frame!
Is this an FCP or AJA problem? Seems outrageous for a product this mature to have such rinky-dink issues that are frustrating and very time consuming. Not to mention the explaining if a client is with you as you try again and again…
My ten-year-old Media 100 hits the mark every time…
