Activity Forums Apple Final Cut Pro Legacy Final cut pro crashes constantly
  • Final cut pro crashes constantly
    Posted by Ross Hammond on October 16, 2005 at 9:59 pm
    Simple as that it crashes when you press space bar too quickly, scrub clips in viewer, use the jog wheel in viewer etc. etc. I tried to use multi clip and it would play for three seconds then crash.
    Also when I import pshop images typically type as a layer, when I render it I get either a green line on one end on my graphic or a pink line only once I render it….
    I use Dual 2.5 G5.
    6 gigs of ram
    Final cut studio5.
    Xserve raid fiber channel.
    Decklink HD pro card.
    No programs are open except for final cut when I am using it.
    Any help is appreciated thank you.
    Ross Hammond replied 20 years, 10 months ago 3 Members · 3 Replies
  • Bouncing Account needs new email address
    October 16, 2005 at 10:56 pm
    THE FOLLOWING COMES FROM THE KEN STONE WEBSITE:
    “Over 5,000 years ago Confucius wrote: ‘If you are toiling away, you have changed nothing and FCP heads South on you, [starts behaving in strange ways] then it is time to trash your FCP Preferences.’ ”
    Click the following link for instructions.
    https://www.kenstone.net/fcp_homepage/trashing_fcp_prefs.html
    A great way to do this is to use “FCP Rescue” a free Apple Script that will Trash the Preferences for you (and restore nearly all of your user settings afterward).
    There are versions for FCPro & FCExpress.
    Download these free Apple Scripts at
    https://fcprescue.andersholck.com/
    This is one FCP tip that has helped in hundreds of “odd” problems.
  • David Roth weiss
    October 16, 2005 at 11:22 pm
    yet another deja vu…
  • Ross Hammond
    October 17, 2005 at 6:07 pm
    Thank you for your help Matte, I will try it out and hopefully it will solve my woes.
