Activity › Forums › Apple Final Cut Pro Legacy › Final Cut Pro – compressor
  • Final Cut Pro – compressor
    Posted by Jpmark on November 9, 2005 at 1:01 am
    I have been attmpting to use compressor to comress a 51 minute project for a DVD. It has worked in the past but isnt now. The audio pass is fine, but the mp2 pass is failing during the first pass each time. It says Quicktime error: 0.
    Rather urgent. Any thoughts?
    Many Thanks, Jpmark
    Jonathan Palmer replied 20 years, 11 months ago 3 Members · 2 Replies
  • Don Greening
    November 9, 2005 at 8:32 am
    If the failure is occuring at the same place each time (check for the percentage completed) it may be a piece of corrupt media. Do you have a still picture in there somewhere like a .jpeg?
    – Don
  • Jonathan Palmer
    November 9, 2005 at 4:41 pm
    Sorry I so late responding-
    I have the same thing happen. There was no reason for the error I could find- Even my pro authoror friend was clue less. The work around I found was to compress with QT pro. It had no problm wioth the media on the hangupp spot.
    Hope that works.
    JP
