Activity Forums Apple Final Cut Pro Legacy Final Cut Pro Compressor Help
  • Final Cut Pro Compressor Help
    Posted by Lauren on August 30, 2005 at 7:14 pm
    Please help ASAP! I need to know the best setting for compressor for a movie that is about 1 hour and 30 min to 1 hour and 45 min. So if you could please tell me the best presets or if i have to make a new one for the movue to get ready for DVD Studio Pro. Also should I have A-Pack do the encoding for the AIFF audio or let DVD Studio Pro do so! Thanks in Advance for your help!!!
    Lauren replied 21 years ago 3 Members · 10 Replies
  • 10 Replies
  • Walter Biscardi
    August 30, 2005 at 7:29 pm
    Just go to Compressor and use the “Best Settings” for 90 minute movie.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
    Now editing “Good Eats” in HD for the Food Network
  • Lauren
    August 30, 2005 at 7:47 pm
    Thank you! What if it is 1 hour and 45 min and where do you find this setting in compressor. I have also heard automatic is not good, do you know why that may be…and should i use a-pack for the sound or just let dvd studio pro do the audio encoding?
  • Lauren
    August 30, 2005 at 7:51 pm
    do you mean mpeg-2? is that better than the dvd preset or creating a quicktime preset?…someone told me to create a preset “QuickTime” dont know if that is right
  • Bret Williams
    August 30, 2005 at 8:07 pm
    Just use the high quality mpeg-2 preset. Use the correlating dolby digital audio preseet.
  • Bret Williams
    There should be a 120 min setting. You’re cutting it too close for the 90min setting.
  • Lauren
    August 30, 2005 at 8:10 pm
    ok so i will use the mpeg-2 90 min and 120 min with the best quality encoding…is that right…thank you for all your help!
  • Bret Williams
    August 31, 2005 at 1:04 am
    That should work. I just used the 90min setting in Compressor 2 yesterday. Didn’t change anything and it looked pretty good. Heck 1 pass VBR is pretty decent, right inside DVD SP. I usually just export qt refs and drop them in DVD SP and use the 1 pass and the aiffs it creates for client approvals. When I get the final approval, I use compressor and dolby digital for the audio, and replace the qt refs with mpeg 2s from compressor.
  • Walter Biscardi
    August 31, 2005 at 9:29 pm
    [Bret Williams] “I usually just export qt refs and drop them in DVD SP and use the 1 pass and the aiffs it creates for client approvals”
    DVD Recorders are even nicer for this. I just run the project directly out to my Philips DVDR-75 recorder and then send that off for Client approval. Real-time and really easy. 🙂
  • Lauren
    September 2, 2005 at 7:28 pm
    Do you mean, just a regular dvd recorder that you can get at Best Buy or so on! What quality should I look for when buying a dvd recorder to get just as good as quality as doing it the way through DVD Studio Pro and a Computer Burner. Also if I export the movie out of the S-Video will it do sound and audio…I didnt think so…Do I need to get one of those splitters also? Please let me know asap!!Thanks for your help!
  • Lauren
    September 3, 2005 at 2:09 am
    Please help/….I got a dvd recorder and it is not recognizing the fcp print to tape…how do i do this…i was using a firewire cable should i use a different connection from apple computer to dvd recoreder!!!
