Activity Forums Apple Final Cut Pro Legacy Final Cut Pro Color Corrector problem
  • Final Cut Pro Color Corrector problem
    Posted by Sam Bebbington on January 27, 2013 at 2:31 pm
    I’ve searched on many forums to find this answer and I’m in a bit of a pickle with it all.
    I’m currently editing a short film and when I’ve come to do my primary color correction as normal i’d add the corrector to the clip, tried both adding it onto the timeline clip and dragging it into the filters tab in the viewer. But it doesn’t apply only when I render.
    Now I decided to apply a 3 way color corrector and that works a treat, no problems no need for rendering before i can view my correction. If needs be i’ll just use this one but I prefer using the single colour corrector.
    It’s a project due friday and I’d rather get this sorted sooner rather than later…
    Many thanks,
    sam
    Laura Peters replied 13 years, 7 months ago 3 Members · 2 Replies
  • Neil Patience
    January 27, 2013 at 7:30 pm
    Hi Sam
    This kind of freaky behaviour is often fixed by a preference trash – have you tried that ?
    If not, easiest way is to use Digital Rebellions Pref Manager. https://www.digitalrebellion.com/prefman/
    Its a free download and may restore normality to your system. If it doesn’t then I have to be honest it is not something that I have personally encountered so perhaps someone else has come across this and can explain your issue but pref trash would be my first port of call.
    best wishes
    Neil
    http://www.patience.tv
  • Laura Peters
    January 28, 2013 at 7:49 pm
    There are two things to keep in mind here:
    1. Whenever Final Cut starts acting weird, it is time to trash FCP preferences. Preference Manager is a good option, you can also do this manually, which I’ve written about here: https://www.larryjordan.biz/trouble
    2. The single-wheel color corrector is OK, but designed for business graphics. Most of the time, you have more control using the 3-way Color Corrector filter. You get the same level of gray-scale control, but much more control over color adjustments.
    Larry
