Activity Forums Apple Final Cut Pro Legacy final cut pro codec not found
  • final cut pro codec not found
    Posted by Marcos Cordova on May 30, 2006 at 9:09 pm
    Hi,i have a problem in final cut ,wen i use the hdv 720p30 secuense they said :codec not found.you may be used a compresion type without the corresponding hardware card, and them:error ,out of memory .I used this codec before and i dont have this problem,i use a Black magic deck link xtream ,osx 10.4.6 quicktime 7.04 and final cut 5.0.4 ,i already instal all this programs and drivers and the thing is the same.
    Thanks.
    Justin Coleman replied 20 years, 2 months ago 2 Members · 4 Replies
  • Justin Coleman
    June 22, 2006 at 3:32 pm
    You have a Quicktime component missing.
    HD > Library> Quicktime>
    I dont know how but it happened to me to. I got a friend to email me the codec from his machine and it solved it.
    Good Luck
  • Marcos Cordova
    June 22, 2006 at 3:43 pm
    Justing thanks for your time ,do you know were y cant download this codec.
    Thanks.
  • Justin Coleman
    June 22, 2006 at 5:39 pm
    Well its a bit tricky,
    Firstly try making a new project of that type and see if it works. Next try a fresh install of FCP, if not then look at that list of Qtime components and post them on here, i’ll look at mine and see if there looks to be one missing.
  • Justin Coleman
    June 22, 2006 at 5:43 pm
    Email me at coleman.justin@gmail.com
    I’ll send you the codec and instructions.
    I have no idea why this is a problem but it drove me mad! HDV 1080i 50 was my problem one, but they are all governed by the same codec.
    So forget that last post of mine ok?
