Activity Forums Blackmagic Design Final Cut Pro Capture Problem
  • Final Cut Pro Capture Problem
    Posted by Joe Quirino on September 19, 2006 at 3:28 pm
    It seems when I capture video with my BMD Multibrdge Extreme after a couple of minutes I get an error message “Tape Problem” And something about threading of my tape. Now it captures fine under non controlable device. I am using a DVC-PRO AJ-D650. I understand if there was a timecode break it would create a new clip, but this just stops recording. My only thought is that the tapes I shoot are in Nondrop from. The capture setting is at 29.97. Do you think that would be the reason for the sudden break? If so, is there a way that I can caputre using BMD at 30 fps? thanks for you help
    Luke Maslen replied 20 years ago 3 Members · 5 Replies
  • Luke Maslen
    September 20, 2006 at 3:02 am
    I’m not sure why that is happening but might have seen something similar before. Please go to the On timecode break pop-up menu and select Warn After Capture. Does this avoid the problem?
    Regards,
    Luke Maslen
    Blackmagic Design
  • Jeff Brown
    September 20, 2006 at 3:09 am
    BTW, lake,
    Drop-frame and non-drop timecode both use 29.97 FPS. It is only the numbering of the frames (via timecode) that is different, not the framerate.
    -jeff
  • Luke Maslen
    September 20, 2006 at 3:44 am
    Kristian just reminded me of a capture issue we’ve seen in Final Cut Pro with some older Panasonic decks. Would you please email support@blackmagic-design.com as we may have a solution which will help with your model of deck.
    Regards,
    Luke Maslen
    Blackmagic Design
  • Joe Quirino
    September 22, 2006 at 1:30 am
    Thanks for the awesome advice. It works awesome. I do not know what I would do with out you guys! Thanks again
  • Luke Maslen
    September 25, 2006 at 5:19 am
    Thanks for letting us know. That’s great news 🙂
    Regards,
    Luke Maslen
    Blackmagic Design
