Final Cut Pro: Audio quality changing in playback…very poor
FINAL CUT PRO AUDIO becoming almost “demo” sounding audio.
I am doing music and sound for a video and I have several audio tracks going.
I find when I load in a music track, at first it sounds normal, but after I edit something else and come back to it the audio changes to almost a “demo” sound, very very low quality, thin and distant. If I delete it and reload the audio back in, it sounds normal again, but will eventually become low quality again. This is very troublesome as I have so many tracks all being edited in different ways. Even when I bounce, if the audio is in its poor quality state, the bounce will reflect that.I did have the sequence settings different from the format I was bouncing too (the sequence was 16 bit 48000 and my audio was 24 bit 44100) but after changing that I still get the same problems.
Any ideas?
