Activity › Forums › Apple Final Cut Pro Legacy › final cut pro audio issues
  • final cut pro audio issues
    Posted by Durango Torres on January 13, 2014 at 9:14 pm
    I’m getting a hum on a track of audio as I play the sequence in fcp, but when I go to the original file and play it in the source window of tcp there is no hum. Has anyone ever had this problem?
    John Fishback
    replied 12 years, 8 months ago
    3 Members · 3 Replies
  • Mark Suszko
    January 13, 2014 at 10:37 pm
    Going to guess only one half of a stereo pair is active, and the other channel is dead. What happens when you pan the channel full-left or full-right?
  • Durango Torres
    January 14, 2014 at 3:41 pm
    Mark – yeah it looks like when I edit in just one channel (both chns have audio in mono dialogue) I get the hum but when I edit in both channels the hum is gone… real weird.
  • John Fishback
    January 14, 2014 at 7:42 pm
    Channels may be 180 degrees out of phase. When both channels are played back mono, the hum would be cancelled out.
    John
    MacPro 8-core 2.8GHz, 16 GB RAM, OS 10.8.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
    FCP-X 10.0.9, Motion 5.0.7, Compressor 4.0.7
    Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
