Activity › Forums › Apple Final Cut Pro Legacy › Final Cut Pro and MiniDV Decks
  • Final Cut Pro and MiniDV Decks
    Posted by Jennifer Marshall on December 3, 2008 at 11:50 pm
    Hello,
    I recently got Final Cut Pro Suite 2. I had the Academic version of Final Cut Pro and I was able to log and capture using my Canon XL2 camera.
    Now I’m looking into getting a MiniDV deck for my computer. I wanted to know what are the best decks out there that are capable of doing HD and regular mini DV tapes. I was also wondering how to get one used or fairly cheap since I’m on a budget.
    Thank you.
    Bill Dewald replied 17 years, 9 months ago 2 Members · 5 Replies
  • Bill Dewald
    December 4, 2008 at 12:41 am
    A reliable deck isn’t really a low-budget purchase. If you’re going to give it enough use that it makes sense for you to buy it, you should probably invest in a new deck with some sort of service plan.
    That said, for the low budget route, i’m fond of the Sony GV-D900. I’ve used a lot of them, and you should be able to find them used for around 500-750 bucks.
    Another low budget option is using a cheaper camcorder as a deck. The Canon HV30 will do both DV and HDV.
    While you can look into HDV decks, which will play both HDV and DV footage, I wouldn’t recommend them, as they would be out of your budget.
  • Jennifer Marshall
    December 4, 2008 at 1:17 am
    Thanks for the info.
    I guess going for a walkman player type deck was what I was thinking of. In particular the Sony GV-HD700 High Definition Walkman. I’m not sure if this product, or anyone similar to it, would be compatible for playing HDV and SD mini DV tapes.
  • Bill Dewald
    December 4, 2008 at 1:30 am
    [Jennifer Marshall] “Sony GV-HD700 High Definition Walkman”
    Right on. Had no idea that that came out. Looks perfect for you.
  • Jennifer Marshall
    December 4, 2008 at 1:34 am
    That’s good to hear. How can one tell if it can play both HDV and SD footage? I figure if it could play HDV it could naturally play SD. Just wanted to make sure before I buy it.
  • Bill Dewald
    December 4, 2008 at 1:49 am
    Just checked the specs at B&H, which affirms that it plays DV and HDV.
    One possible gotcha – there are compatibility issues between some Canon HDV modes and some Sony decks. I’d do a test before, say, shooting a lot of progressive 1080 with a a Canon.
    https://www.bhphotovideo.com/c/product/516841-REG/Sony_GVHD700_GV_HD700_HDV_Video_Walkman.html#specifications
    There have been detailed threads about this issue before – read up on it in the HDV forum.
