Activity › Forums › Apple Final Cut Pro Legacy › Final Cut Pro and Compressor quitting
Posted by Kai Mariah on May 7, 2011 at 6:51 pmHi.
I have a file that is approx 90 minutes long that I’m trying to export to a quicktime movie file so that I can put it on DVD.I tried it using compressor. It failed fairly early in the process but I don’t know why it failed. I tried a couple times but it keeps failing.
Now I’m trying to just export it as a quicktime movie using the default settings. It keeps quitting unexpectedly — the only message I get is that it is having trouble with free effects mac plugins.
I trashed the preferences but that didn’t help.
Any ideas how to fix this? I need to get it done today.
Thanks.
Kai MariahKai Mariah replied 15 years, 3 months ago 4 Members · 9 Replies -
Everest Mokaeff
May 7, 2011 at 7:45 pmWhat kind of file is that? Codec? Container? Is it a fcp sequence or self-contained file?
Free-lance fcp editor in Moscow
http://www.mokaeff.com -
Kai Mariah
May 7, 2011 at 7:49 pmHi.
The file is a sequence in FCP. I’m trying to make it to a self-contained movie.
When I set the preferences it automatically sets it to DV_NTSC. -
Everest Mokaeff
May 7, 2011 at 7:59 pmDoes you sequence contain footage of varying resolutions and frame-rates? Is your captured footage dv? What particular effects and filters did you apply? Can you tell from export progress what part of your sequence went awry. Did you try partial export in order to localize the problem spot?
Kai Mariah
May 7, 2011 at 8:07 pmDoes you sequence contain footage of varying resolutions and frame-rates?
There’s not a lot of video footage in the sequence. I’m working on an animation that was created in DAZ studio. Those clips are rendered to a .mov file and then brought into FCP.
However, I am using various photos, which have different sizes and resolutions. I’m applying a cartoon filter to most of the photos.
Is your captured footage dv? I have some captured footage that was shot on mini-DV.
What particular effects and filters did you apply? Mostly the cartoon filter but I also use a zoom filter, ripple dissolve, cross-fade.
Can you tell from export progress what part of your sequence went awry. I think it’s the first half of the film. It seems to quit when it gets to about 30%.
Did you try partial export in order to localize the problem spot? I’ve tried doing the first half and then the second half. Both seem to take a really long time. If I try to force a quit, it tells me FCP is not responding.
Thanks.
KaiFree-lance fcp editor in Moscow
https://www.mokaeff.com -
Everest Mokaeff
May 7, 2011 at 8:20 pmI bet the problem somewhere among your stills. If you have pretty large stills they may cause the trouble. Try to steer clear of any bmps, gifs and heavily compressed jpgs. Instead use tiffs or pngs with video compatible resolution of 72 Do you work in Dv NTSC sequence? I am afraid you’d have to find exact trouble maker on your timeline and deal with it.
Rafael Amador
May 7, 2011 at 8:48 pmProbably there is an element in your sequence that aborts the rendering.
The only way to discover the offending media is to render your time-line by batches.
Select a portion of your sequence and “Alt-R” to make sure you render everything in the selection.
When FC crash again you found the clip that is bothering.[Kai Mariah] “. It keeps quitting unexpectedly — the only message I get is that it is having trouble with free effects mac plugins.”
Are you using any kind of third part plugin ?
rafael -
Kai Mariah
May 7, 2011 at 9:23 pmThanks. Would it have anything to do with files that have gone offline? I have one file for sure that was deleted. It keeps showing up in the list of files that have gone offline. I don’t know how to get it off the list. It’s not showing up in my browser.
Kai
David Eaks
May 7, 2011 at 10:20 pmIs the offline file on your timeline? That sounds like a likely culprit. If a file is deleted, it goes offline. Then you delete it from both timeline and browser, save and quit, it won’t show the “reconnect media” dialog upon opening the FCP project. The offline file is there somewhere.
Kai Mariah
May 7, 2011 at 11:28 pmOK. I found all the files in the timeline and the browser that should have been deleted. Now it’s telling me that there are 307 render files that are offline. I’m sure that’s because I deleted a back-up copy that was on the internal hard drive. How do I get rid of that?
Kai
