Activity Forums Apple Final Cut Pro Legacy Final Cut Pro and .ale file???
  • Final Cut Pro and .ale file???
    Posted by David Bertman on July 26, 2005 at 1:21 am
    I am planning on editing an HD project. The lab wants to give me downconverted 29.97 fps DVCam tapes of selects with an .ale file…
    They sent me a sample .ale file to import. I tried to read it into FCP and it wouldnt allow me to import. Is there some program that I need to run it through to make it readable to FCP? I’m surprised FCP cant do the industry standard files (.ale and .flx)… Or… maybe its me. Am I doing something wrong?
    David Rowan replied 21 years, 2 months ago 4 Members · 3 Replies
  • Santiago Gutierrez
    July 26, 2005 at 3:18 am
    Cinema Tools 3 will do this for you. You just need to import the .ale file as a ‘Telecine Log’. This will set up a database of the footage for you.
  • Bret Williams
    July 26, 2005 at 3:30 am
    Even simpler, download sebsky tools. It has a little tool called ale2fcp and also fcp2ale.
    https://www.dharmafilm.com/sebskytools/download.html
    It just saves your ale as a fcp batch file you import into a bin.
  • David Rowan
    July 26, 2005 at 4:23 am
    Actually they want you to drink some Ale before you send the stuff over. To relax you.
    DWR
