Activity › Forums › Apple Final Cut Pro Legacy › Final Cut Pro 7.03
Final Cut Pro 7.03
Posted by Roger Nissenbaum on July 19, 2016 at 8:41 pmIs there a way to pull up all files used in an edited piece in FPC 7.03?
Roger
Roger
Nick Meyers replied 10 years, 1 month ago 3 Members · 2 Replies -
Shane Ross
July 20, 2016 at 12:54 amHow do you mean? Link to all the clips used in a bin? ON the hard drive? You can MEDIA MANAGE them and copy over all the clips used in a sequence, yes. The full clips, or just the parts used in your cut, with handles/
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Nick Meyers
July 20, 2016 at 7:56 amyour question is a little bit vague!
if you want to get all the used clips into a new bin, copy the sequence into a new project,
then Tools Menu > Create Master Clips.you’ll get one instance of every master clip used in the timeline.
you’ll also get master clips for each text (or other) generator,
so maybe clear them out first if you want.nick
