Activity Forums Adobe After Effects Final Cut Pro 7 XML to After Effects CS6
  • Marla Singer
    September 14, 2012 at 8:08 pm
    Hi Stephen,
    I’ve done it a few times, and it’s not that tricky. Just export the xml as you usually do on FCP, and then on AE6 go to: File-Import-Pro Import After Effects
    That command pops up a window to allow you to choose certain settings, but the default ones should be fine.
    Good luck!
  • Harkirat Singh
    May 6, 2015 at 8:52 am
    Thank you so much. That solved my problem too
