Final Cut Pro 7 refuses to make a reference mov
Hi, thanks so much for your time.
I have been trying to do something I’ve done many many times and now for some inexplicable reason it’s not working. I’m just trying to make a reference mov. The clips match the sequence settings, it’s Apple ProRes 422 Proxy, I’ve done a couple of simple edits, added audio, and I should be able to export a reference mov with a negligible file size just by unticking “Make Movie Self-Contained”. But instead of being an instant export, it takes a minute and I end up with a file a few hundred megs in size, as though it’s had to render something, except there’s clearly nothing to render. Does anyone have any idea what could be causing this?
Thanks in advance.
