Activity › Forums › Apple Final Cut Pro Legacy › Final Cut Pro 7 RED workflow problem
  • Final Cut Pro 7 RED workflow problem
    Posted by James Nickell on March 14, 2015 at 4:45 am
    Ok so I have a short film I’m editing, it’s about 30 mins long. I transcoded the Red footage using RedCine X-Pro to apple prores 720P for an offline edit. I edited the film, have picture lock, I export an XML of the project with no audio files and all video files on track one. I import the XML into RedCine X-Pro and reconnect to the original red files. When the timeline loads up in RedCine X it only loads the first frame of each shot and leaves the rest of the shot blank. They want a 4K and 2K version of this film. I did this same work flow with a feature and it worked flawlessly, now it’s all messed up, any one have any problems with this?
    Rainer Wirth replied 11 years, 6 months ago 2 Members · 1 Reply
  • Rainer Wirth
    March 15, 2015 at 1:15 pm
    Something was different between the working workflow and the last workflow that failed.
    Any software updates between the two?
    cheers
    Rainer
    factstory
    Rainer Wirth
    phone_0049-177-2156086
    Mac pro 8core
    Adobe,FCP,Avid
    several raid systems
