Activity › Forums › Apple Final Cut Pro Legacy › Final Cut Pro 7 recommended resolution?
  • Final Cut Pro 7 recommended resolution?
    Posted by Elizabeth Johnson on January 8, 2012 at 5:01 pm
    Hi all,
    Does one have to run FCP 7.0 at the recommended resolution of 1280×800?
    My Macbook Pro video display died, and the Apple technician suggested connecting the laptop to an external monitor. He recommended the Samsung 39cm (1336×768) Wide LED Monitor, series 1 SA100, and said this would be the same as my Macbook Pro 15″ screen.
    However, in the System Preferences – Display, I cannot suggest a screen resolution of 1280×800, likely because the monitor is 1336×768. The display settings open two windows-Color LCD and SMS16A100. In the Color LCD, I can select 1280×800. In the SMS16A100 window, I can select 1024×768, 1280×720 up to 1360×768.
    When I try to run FCP 7.0, it says it recommends a resolution of 1280×800. If I cant set that resolution, it warns the program will run strangely. What can I do?
    Any advise would be very much appreciated. Thank you in advance for any
    suggestions!
    Cheers,
    Elissa
    Life is worth living.
    Bret Williams replied 14 years, 8 months ago 3 Members · 2 Replies
  • Jerry Hofmann
    January 8, 2012 at 9:13 pm
    I think you need a different computer display. Otherwise, what will happen is that you’ll likely see the video distorted a bit in the viewer and canvas. Won’t actually distort it, but you’ll see it that way. I’d look at a different monitor.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Bret Williams
    January 9, 2012 at 9:46 pm
    I think that’s a minimum Rez needed to fit all the windows. It appears you’re using a 720p HD monitor as your computer display. A little confining but I would think it would be fine. We used to run FCP on 800×600 laptops no problem. The interface hasnt changed much. But video is 16:9 now. But no reason you wouldn’t just scale down the images in canvas and viewer.
